ItlanChode
4200: http://www.newegg.com/Product/Product.asp?item=N82E16819103547
4000: http://www.newegg.com/Product/Product.asp?Item=N82E16819103497
Friends suggest 4000, this site suggests 4200. I will mostly gaming, and the most multi-tasking I will be doing is iTunes + Gaming, iTunes + Porn, etc. not Much multi-tasking. So which do you think I should go with?
P.S. What's the difference between the above 4000 and this one?:
http://www.newegg.com/Product/Product.asp?Item=N82E16819103529
Thanks!
Thanks!
