a123
hello! this is my first attempt on this CPU. I did not touch the voltages as i want this CPU to last. Are the load temps are a problem?
if it is, i'm considering an Arctic Freezer 64 Pro. i'd be looking for a cool and quiet cooler, so would this be good? Or any other suggestions that cool well and are more quiet and not too expensive at the same time? The idle temps are around 36-39C btw
the oc went all the way up to 2.81ghz but Prime95 found errors so i lowered the speed until it had no problems. At 2.81ghz, it took superpi 34 seconds to do 1m. When Prime95 finds errors, what is actually the problem?
Thanks for your help =]
