I think its only working with the GTX and ultra, from what i hear. Im not sure though.
So is it actually worth it? Or sort of a waste like normal SLI?
So you are not satisfied? What sort of issues, or problems dissatisfy you?
Yeah, that's too bad. A system like yours should run anything perfectly.
On high, 20-40 fps. Very high sucks, and that's one of the reasons I'm dissapointed. [/jack]
Are you sure SLI is enabled? (dumb question im sure)
yea but i heard/read in forums that crysis doesnt enable the sli yet...still waiting on a patch, just like it doesnt have the 4 core utilization it said it would for quad core processors...just read it somewhere, so dont give up just yet...i get the same frame rate as u, but i have 3 very high settings.. so it sounds like ur only using one card n e way in that game..
