A Gaming Case
Aloush
Would you recommend me a nice gaming case which looks good and has maybe some LED lights on
Thanks
My budget im not sure i am hoping to build a brand new computer maybe on £350-£400
So you want to go cheap on a case right? A good gaming case can cost almost a 1/8 of what you want to spend on a total system.
One of the ones I like cost $384, so I am guessing that's out of your price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235005
Do want one with a front door? Personally I do not like them, but some do. Do want a removable motherboard plate? Are you planning on installing a large GPU like a 8800?
Do you want a mid or full tower case?
Heres another interesting case. I have not used one yet, but I am curious about it. I have read some good reviews though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138
A mid tower case with a door if you can find one and i might put some extra money towards a case so post some good ones that are not to expensive
