My build in full ... what u all think .. should i make any changes?
LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM
Item #: N82E16827106228
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811129021
Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Item #: N82E16822136011
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822148262
EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130312
Rosewill RX750-S-B ATX12V v2.2 & EPS12V v2.91 750W Power Supply - Retail
Item #: N82E16817182067
2x Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK - Retail
Item #: N82E16820220144
Open Box: GIGABYTE GA-P35C-DS3R LGA 775 Intel P35 ATX Intel Motherboard
Item #: N82E16813128048R
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
Item #: N82E16819115017
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
Item #: N82E16832116204
$1538 before rebates
What would u guys change? i would like to drop the total down 200.
ill admit it bro u help me alot.. i combined 2 threads i had of stuff that u relied on and mixed stuff up... ill prob order the case and the processor from those 2 site since there alot cheaper.. and dont have to deal with mail in rebates...
also the PSU that daisy posted... ill prob switch mine out with that one...
now one more question ... the hard drives will i have a problem with the Rapter being a ATA150 and the seagate being a SATA
also the mother board... shall i change it?
and the DVD burner why shall i change it to a SATA?
IDE cable is big. Block airflow.
IMO, I prefer modular PSU than normal one. But the Coolermaster one is in good price...
WD Raptor is SATA
so change the WD raptor to SATA and the DVD to SATA...
bleh i dont think the raptors come in SATA... just looked... is that bad?
also the DVD burner .. which do u suggest...
The Raptor and Raptor X are both SATA (I have one of each).
The case, while it looks pretty, is a pain. I don't recommend it. If you stick with it, buy a PSU with extra long cables, or you'll be buying extensions.
Rosewill PSUs are cheap. I would get a better unit, personally.
I'm not thrilled with the RaptorX performance. I would get the WD740 for your main drive. You'll probably find that it outperforms the RaptorX.
