Hi,I have 2 intel pentium III cpus just lying around from previous computers..One is 1.0 GHZ,and the other is 866 MHZ,both have the same voltage and actually came from the same compaq deskpros,just different speeds..
I was wondering if I could buy an Intel STL2 motherboard and use those processors I have on there? would that give me 1.833 GHZ?
Also would i be able to run a non server program with that? say windows xp home?
Will the compaq power supply (deskpro 135w) handle the dual processor motherboard ?
Will it be decently fast?
I wanted to experience the dual cpu without spending alot..This motherboard is around $30..
EDIT..Will that motherboard fit in my full size tower atx?
here are the specs from the website,thanks in advance.
Intel STL2 Dual Socket 370 Server Mother Board w/VRM & LAN
"The STL2 motherboard's scalability provides the performance needed for today's unpredictable e-Business economy. It supports up to two Intel Pentium III processors with 133MHz system bus and six PCI slots. Two of the PCI slots are on an independent, 64-bit/66MHz PCI bus, which provides added I/O throughput. Additional server technologies include the Intel PRO/100+ Fast Ethernet Controller, Ultra160 SCSI storage, 4GB of PC133 ECC SDRAM memory capacity and Intel server management."
