Universal Laptop Battery?
chrislo
I own a Toshiba Satellite Laptop and its normal battery doesn't last too long. I was wondering if anyone sells a universal laptop battery that can connect through the power jack on my laptop and power my laptop after the battery runs low? I think APC sells a similar product but I haven't been able to find it.
With some tweaking you could probably extend the battery life a bit. Running at a lower clock speed, less cpu voltage, etc etc... Doing so greatly increased the life of my old Averatec laptop.
As for external batteries, I don't know of any right off, but it wouldn't be too difficult to make something. Every laptop I've used has a DC input, typically around 12-20v. If you found what yours uses then mocked up something, you could probably power it. Though your best bet may be to simply look around for original batteries. Sometimes you can find used ones that still hold a charge.
Maybe recalibrate the battery 1st.
My 2year old hp laptop battery was lasting only 20 minutes.It went from 100% to 20% really quick and hibernated.Even though it's set at 3% to hibernate.
Now it lasts about an 1hr30min.Still sucks compared to the 3hrs it used to last but my 12 cell is almost here:)
Anyway,to recalibrate the battery,1st charge it up to 100%,then remove the power supply and let it die completely,meaning go into power properties and turn off the hibernate and turnoff stuff that it does when the battery gets low,,it has to actually die and turn off by itself..Mine was so out of wack it was at 0% for about 45 minutes..
Then you plug back in the laptop but dont turn it on,,just fully charge it untill the battery charge light goes out..
Done..
If it doesn't work it doesn't work,but it's free so try it.
Also,turning down the screen brightness helps A LOT,and turning off the wi-fi when it's not in use.
I've seen the APC universal batteries at Compusa. I don't know if you have one in your city but they're going out of business where I am at. Try finding it online.
I have no problem changing setting in the BIOS, but will the changes have negative effects on my laptop? As for the battery I was talking about, I want something that just clips on to the bottom of the laptop and connects to the DC power port. When the standard battery goes dead it switches to that battery. I don't know much about the APC battery so if you have more information on it I would be grateful if you shared it with me. Thanks.
