Need help building a new computer?
Unbob22
Hi, I'm building a PC at the moment and was wondering if you can tell me if these are good enough (only have about $1000 to $1600):
Intel Core™2 Quad Processor Q6600 2.4GHz w/ 2x4MB Cache
http://www.memoryexpress.com/Products.aspx?ProductID=MX15884(ME)&curtab=0
Antec EarthWatts 500W Power Supply
http://www.memoryexpress.com/Products.aspx?ProductID=MX18432(ME)
LG 16X DVD-ROM, Black (OEM)
http://www.memoryexpress.com/Products.aspx?ProductID=MX18882(ME)
Corsair 2GB XMS2-6400C4 TWIN2X Dual Channel DDR2 Kit (2 x 1GB)
http://www.memoryexpress.com/Products.aspx?ProductID=MX13900(ME)&curtab=0
Seagate 320GB Barracuda 7200.10 SATA II w/ NCQ, 16MB Cache
http://www.memoryexpress.com/Products.aspx?ProductID=MX12631(ME)
ANTEC Nine Hundred Ultimate Gamer Case
http://www.memoryexpress.com/Products.aspx?ProductID=MX14869(ME)&curtab=0
eVGA e-GeForce 8800 GT 512MB PCI-E w/ Dual DVI, HDTV-Out
http://www.memoryexpress.com/Products/PID-MX19670(ME).aspx
Intel 975XBX2KR Motherboard - Intel 975X, Socket 775, ATX, Viiv Ready, Audio, PCI Express, Gigabit LAN, S/PDIF, USB 2.0 & Firewire, Serial ATA, RAID
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2563503&CatId=2438
Is the PSU good enough, should I get a higher Watt one or will it just damage the computer?
Is this good enough, is there anything I should change or missing?, and will all these work together?
O BTW, I didn't compare the price yet, just trying to figure out the parts I need and if they work together.
Thank You very much for your time!
Edit: I fixed up the links
Many of the links don't work but based on your descriptions I'd change the following parts:
Q6600 for a G0 one from ClubIT (The G0 stepping is generally better)
The PSU for something more like a Corsair HX520W if you can stretch that far.
The motherboard for a Gigabyte, Abit or Asus P35.
Otherwise it's a good build, but is that DVD drive a writer or reader?
The G0 stepping is more energy effecient and because of this it overclocks better. People have been able to get those chips to 3.6-4GHz, although even 3.4Ghz is good, but you'd need an aftermarket cooler, a Zalman CNPS-9500 or an Arctic Cooling Freezer 7 Pro would be a good choice.
ooo I see
Are you good with your hands? Ever built a computer before? Can you look at something and figure out how to do it?
If not, then do NOT get the Antec 900 case. It is one PAIN to put together.
If you have experience with computers and don't mind some frustration, then go ahead and get it.
Really? Can you suggest another case for me then? I was thinking of getting the Antec 900 cause I heard good things about it.
The Antec 900 is a great choice. OMEGA has a guide on this forum, so you should't have to worry about it :)
But then again oscaryu1 has never actually built a system with this case, so he has no idea.
And if someone had to write a guide to use it, how simple can it be to use?
