good 22" widescreen lcd brand?
newguy5
i was wondering what you guys think? i actually have a westinghouse 20" non-widescreen, but even though i've had it for under 3 months, best buy won't let me switch it out for their same model but widescreen version. that irritates me. i know it's supposed to be only a 30 day guarantee, but they didn't have the widescreen when i bought mine and i hadn't decided to build my computer yet which supports widescreen. anyway, are there any loopholes there that you guys know of? if not, what about good brands for lcd monitors? thanks.
samsung or NEC are my favorites, nec can be pricey at times, (around $360 for a very nice model,) but nec monitors are well worth the price in my mind
The reason i dont go for samsung monitors, you never know if your going to get a good or bad panel. They use i think 3 different lcd panels on the same model, the "S" panel is the one you want.. but it doesn't always happen that way.
Heres the one i got at best buy, a great monitor. I bought it for mostly gaming since it has a fast refresh rate a 3000:1 contrast ratio.
http://www.bestbuy.com/site/olspage...G+22"&lp=1&type=product&cp=1&id=1177112467150
At that price, it was a no-brainer for me :)
Yeah, there are S, A, and C panels. The S are made by samsung, the A by AU Optronics and the C by some crap company. The A panels aren't that bad, and according to a review(i will find the link later) the only real difference is that the A's have a bit of blue dominance, which can be fixed pretty easily.
I have a Samsung 206BW and i got the A Panel(i was able to tell by the blue dominance) and i managed to fix it.
I have a Belinea 22" widescreen. It may not look as pretty as Samsung screens but I've never had any complaints.
For the best all around monitor look for a fast response S-IPS panel which are the same types used in the 30 inch Dell and Apple. Not all S-IPS panels are equal but the good ones are hard to beat. Some S-IPS panels have slow response times so another alternative would be to go with an S-PVA panel which is the type panel used in the 30 inch Samsung model. Here is a quick run down of the differences in types of panels..
TN film (Twisted Nematic)
- low manufacturing/retail costs
- restrictive viewing angles
- fast pixel response times
- dead pixels display white. Stuck pixels display RGB colors
- lower contrast levels means blacks are not as dark as VA based panels
- lower color reproduction
IPS (In Plane Switching)
- improved viewing angles over TN
- very good color reproduction
- slower pixel response times than TN
- dead pixels display black
Super-IPS (S-IPS)
- same as IPS except ...
- likely best color reproduction of all TFT
- less expensive to produce than IPS
- improved pixel response
VA (Vertical Alignment) Technologies
MVA (Multidomain Vertical Alignment)
- compromise between TN and IPS technologies
- superior color reproduction over TN but not as good as IPS
- very good viewing angles but less than IPS
- higher contrast than TN or S-IPS means very good blacks
- dead pixels are black
- slower pixel response than TN or IPS
- details can be lost when directly viewing dark areas
Premium-MVA (P-MVA)
- same as MVA except ...
- "overdrive" technology increases pixel response but still slower than TN
- may have slightly degraded color reproduction due to "overdrive" process
PVA (Patterned VA)
- larger viewing angles
- higher contrast levels means darkest blacks
Super-PVA (S-PVA)
- same as PVA except ...
- “Magic Speed” (the Samsung equivalent to Overdrive) improves pixel response
- slightly improved color reproduction
- slightly improved viewing angles
acer. theyre really great, believe me, i have one and my sister has one.
they pwn :D
I think I have to disagree there. I sell Acers, and I have a 22" and 2 19" Acer widescreens here in the office. They're *ok*, decent for the money, but they ANYTHING but pwn. This one sitting beside me is an LG 19" widescreen and it totally destroys the Acer.
For a value screen they do the trick, but the colors are mediocre. Performance in games is equally mediocre. It's fine, just not "fabulous" or "pwnage" or anything.
any comments on the westinghouse? i was thinking about going up and just asking a manager if i can swap the one i have now for the 22" widescreen made by westinghouse, but if i'm better off just spending the money on a better monitor, i have no problem with that.
westinghouse would make ok office monitors, but they are not worth the money you put into them... from what i have heard, your best bet is a samsung that you can return if necessary, from me and my love of nec's, and i have always known lg to make quality products, i simply never owned one of their monitors :)
Two of my friends had 22" Westinghouse monitors and they were great, one of them still has that monitor as well (the other person has his damaged physically).
yeah i wish i could switch the the 22" westinghouse, but best buy's return policy just isn't going to allow for it. o well. this is not a bad monitor, but i will probably just buy an LG or samsung down the line and have a very nice monitor. i'll just watch the sales.
The Dell E228WFP is a really good 22" lcd in my opinion. I have one and i have no complaints its awesome even for gaming. The games are so sharp and clear, no dead pixels and no ghosting.
slight change of subject, but it is my thread so i can do that :P
but, what is a good safe brightness to leave lcd monitors at? i have always hear you weren't supposed to leave them really high on brightness. is that true?
I havn't heard of them dying due to high brightness...but I do know that if you leave it high...you'll burn your eyes out lol.
