Ink cartilage
mkjaekmi
How can I check how much ink is left in my ink cartilage in my printer? Is there a way to find that out or a program I can d/l?
Thank You
i believe it's spelt 'cartridge' my good man, sorry had a good laugh at cartilage.. but, if you can just pop it out and look thats the easiest, sometimes if you put in a new set the computer will monitor it though
Some printer driver installations have ink level monitor software, so you can click on a button and have a thermometer-like gauge of how full your cartridges are. Others have no warning at all and the first sign you need ink is a lousy print!
Tom
Like OverMaster said most printers have a level check program included in the drivers/software.
Thank You
Usually included in the software, usually shows while printing, and also shows when you try to clean your heads.
