sniperchang
OC Stability tests. Prime95, Super PI and OCCT
Would you agree? Would this be the most thorough and efficient way to test an OC?
EDIT:
Super PI
Same Question.
EDIT2:
Any one used OCCT?
Wikipedia said:In the overclocking community a rule of thumb is often used to determine how long to run Prime95: test the CPU (8KB FFT) for 10 hours and the memory (4096KB FFT) for 10 hours, and if the system passes, there is a high chance that it is stable. (link)
EDIT:
Super PI
Wikipedia said:The program can also be used to test the stability of a certain overclock speed. If a computer is able to calculate PI to the 32 millionth place after the decimal without mistake, it is considered to be moderately stable in terms of RAM and CPU. (link)
Same Question.
EDIT2:
Any one used OCCT?
