JohnJSal
I've read that the minimum you should get is 18A on a single 12V rail, but if you do gaming you should look for something in the range of 22A to 32A. But how does this work for multiple 12V rails? I know you don't just add up all the amperage, exactly, so how can you tell if a PSU is sufficient?
Here's one I'm looking at: http://www.newegg.com/Product/Product.aspx?Item=N82E16817153039
It has 4 12V rails, each with 18A output. How does this translate into the way the different components will use it? If a particular GPU needs something like 32A, then does that mean the GPU will draw power from 2 of the rails?
