Hd Tv
ELITE1013
is there any way to connect a computer wit an s-video port, a VGA port, and some USB 2.0 ports to an HD TV and have it be in HD?
It is possible. With your method, I am not sure.
I stream free HDTV, with a USB TV Tuner. I use it on my Mac, but I am sure its PC compatible. The tuner itself is $150, but that comes free with their TV service, which is mostly HD content, if not, high quality TV. I bought an actual antenna, thats use is for this purpose, it works great.
I'll edit in the link for the tuner.
Edit.
Alright, here is the link to the tuner I have.
http://www.elgato.com/elgato/na/mainmenu/products/hybrid/product1.en.html
The tuner itself is not PC compatible, but the software it uses to receive the TV works with PC tuners, with an antenna, I think.
huh funny,seems u really like hd.
it's up to your tv.so what interface your tv have?i know some tv with vga port directly,and then it is easy.otherwise some "advanced" tv only have fukin hdmi and u have to buy a switch from vga to hdmi.
ive seen such a switch dvi2hdmi before
