Hi there. New to the forum and seeking help.
My old laptop has slowly been getting worse and worse. It's slow, crashes frequently, and the CD drive seems to only function if I hold the tray closed tight against the machine.
I want to reformat the harddrive and start again.
The problem is I have a lot of data on the machine. I bought an external harddrive intending to transfer everything on to that but the laptop doesn't recognise it when I plug in the USB cable.
My current way of thinking is to buy a cheap new 2.5 inch harddrive and swapping the old one out. Hopefully then I can put the old harddrive in an enclosure and get the data off that.
Then I can shove the new (I'm presuming IDE???) hardrive into my laptop and start afresh with the machine.
Where are the noob faults in my plan?
Thanks for any help you can offer.
