ah, well i can't help you then. i just assumed it would be since most are. you could always go for the closest to it, since even all of the same type of cards don't even run the same anyway...might be comparable.
Here's an Anandtech benchmark comparing the GTS to the Ultra. In 6 of the tests, the 8800gts directly compares, in three the Ultra is better, and in two the GTS is better. Better than the GTX by the smallest degree, I would say, and just almost the Ultra's peer.
For all purposes, the 8800gts offers just as much performance as the Ultra.
