killer.pollo
Basically I'm trying to upgrade my computer I have an hp dv6119us it has 2x512mb of DDR2 ram and was wondering if I could upgrade to 2x2GB DDR2 800 even though the hp website says that I can upgrade to 2GB and wanna know if it will work right even though I'm going over the max recommended ram, or that i'm getting DDR2 800.
Also wondering if there is much difference between SATA300 and SATA150 since i'm wondering about buying a 200gb 7200 rpm drive to replace the 80gb 5400rpm drive. Thanks a lot any help would be wonderful. The new hard drive would be SATA 150 for some reason.
running 1.6 GHz AMD Turion™ 64 X2 Dual-Core Mobile Technology TL-50
with windows xp installed and dont ask why but i'm hoping to install windows vista with the upgrade
