What we want for our server
Platinum
We have a server here that we want to setup as a file server. What we really want is two 500gb+ drives which mirror each other in case one fails. 1 problem... the server only supprots SCSI drives which can only support up to 300gb per drive. So... we basically need to get 4. Is there a way to have 2 of these drives setup in a RAID, which will then be mirrored to thse other 2 drives?
Maybe have 2 300gb drives act as 1 drive, and be mirrored to the other 2, which are also acting as 1 drive
it's not really my expertise, raid and all.
but if you can make 2 sets of drives in raid in your hardware config
and then mirror the 2 drives you see in windows using disk manager.
or am i talking total crap here? i've never used raid setups before
I don't recommend any of that. Set up a RAID 5 array, if you have 4 drives. Set it up as a 3 drive array with a spare. So you will have 300 gig x3 (just under a TB) and with the spare drive if any of the drives fail the spare will rebuild the array, and then all you have to do is swap out the bad drive.
I just did this exact same thing this week. We have some old Compaq dual xeon 2.5 servers w/ raid and 2 gigs of RAM. There was no OS on them, so I slapped Linux on it, set up a samba server and a share. Gave it an IP and tossed it on a managed switch on a VLAN with all the other servers (my cisco guy did the switch config). Now my users have access to RAID 5 file server share. However, I only have three drives so I am not running with a spare.
The tricky part will be setting up permissions for the shares, and if you are making a part of your domain network at work you may need to bind it to your DNS server and your LDAP directory. If its going to be for a limited amount of users, just set up its own local user:group and give that information out to your users who need to map it.
Not necessary. DNS is for resolving domain to IP. On a local domain, all you have to do is use UNC and map the shares to the file server.
hence the part where I said, "you may":)
If domain users are mapping it, the easiest way is to make it part of the domain, IMO. There are always many ways to accomplish something though.
I have the same setup here. All my computers are on a local domain, as well as my file server. I just mapped the shares and it works perfect. :)
