The link to that base document http://docs.info.apple.com/article.html?artnum=305289Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document #305289.
Whenever I get these problems, I navigate to the registry and delete the existing registry entries for iTunes. And do a fresh install.
This is not recommended, but it works for me most of the time.![]()
Uninstall iTunes, and run the registry cleaner CCleaner
http://www.download.com/CCleaner/3000-2144_4-10780785.html?tag=lst-1
Then reinstall. I wouldn't mess with the registries manually.
Maybe iTunes just hates you?
