Which card do you think is the best.
well definately one of the 512 mb ones.
the 640 mb is the older G80 chipset.
the others are G92.
i like the XFX better. i have the XFX 8800GT.
otherwise theres no real difference apart from the BFG being overclocked a tiny bit.
With all due respect, why are you running the Phenom and an AMD chipset without a Radeon card? Get the 3870. ;)
does it make a difference?
Technically, yes. Basically, the 790FX is designed for AMD cards. You can run up to four in Crossfire, for example. With a nVidia card, you're limited to one. Besides, the 3870 is arguably the best value with regard to the so-called price/performance ratio. :D
So I guess it will be down to the 2 g92's.
The only difference really between the 2 is that the BFG has the nice lifetime warrenty, but i hear xfx has a good one too. Ive always had xfx so I want to stick with them.
The reason i like nvidia is becase there are 400 cards vs ati's 200 cards. more choice and more upgradability. and who the **** needs 4 cards, or 3. my mobo is good for 4 when the time comes.
Both cards are technically and mechanically the same anyway, the only difference is the bundled kit and the warranties. Look at them and you'll see what I mean.
Well thats what I'm saying. With those two cards, the only difference is the clock speed. If the BFG has a little better clock speed is it really that much of a differnce if they have the same bit and mb ratio.
man check out the XFX warranty. its awesome.
http://www.xfxforce.com/web/support/showWarranty.jspa?regionId=1&productGenerationId=730964
its lifetime warranty.
and if you sell the card the buyer will get the warranty as well.
plus, from what i can see, they will still do it if its been overclocked.
We will repair and service your 6, 7, and 8 Series Graphics Card for as long
as you live. Even for those of you who know how to push our cards to the limits, if anything goes wrong, we’ll service it free of charge.
I'm having issues with mine so I'm going to send it back. And I'm going to go with something a little better. Tell me which one out of these you think is the best card.
XFX 8800 gts 512mb 256bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150261
BFG 8800 gts 512mb 256bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143119
EVGA 8800 gts 640mb 320bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130317
GTS G92. By lots. Other alternatives:
HD3870/HD3850.
