Writing a Batch File to create a SHORTCUT
zrebar
HI
I wanna write a batch file to create a shortcut from a file or a folder .
help me about it .
thanks.
please.:confused::confused::confused::confused::confused::confused::confused::confused::confused:
i am not writing a virus!!!!!!!!
You're writing batch viruses??
It's easy copy command but i'm not sure should I help on this time...
i am not writing a virus, i want to create a setup program to install an application. by creating a shortcut, i want to add my application to ALL PROGRAM List . Help me Please......:(:(:(:(:(:(:(:(:(:(:(:(:(:(:(:(:(:(:(
Ok then visit this website it's where I learnt. Easy explained, just follow the prompts and I wish you luck! It's not as easy as create a batch file to delete Windows without asking for permission of an user.
how i can use it?
thanks for your attention
i had visited that page, but i cant use it. help me further to use it please.
thanks for your attention again.:confused:
how i can use it?
