JLV2k5 Active Member Jan 14, 2008 #1 Here are too RAMs that apply to my planned system. SLI type Regular What is the difference besides the SLI, if any? And is it okay to run SLI ready RAM in non SLI system, with only one GPU? Thanks.
Geoff VIP Member Jan 14, 2008 #2 I would go with the first kit if you don't mind waiting for the rebate, as it does have lower latencies.
Geoff VIP Member Jan 14, 2008 #4 JLV2k5 said: So is it fine to use SLI RAM outside of an SLI setup? Thanks Click to expand... Yes it's perfectly fine.
JLV2k5 Active Member Jan 14, 2008 #5 Thanks. So what is the difference between SLI RAM and non SLI ram? Does it simply work better with two GPUs than RAM that isnt made for this purpose?
StrangleHold Moderator Staff member Jan 14, 2008 #6 Its nothing no more than extra EPP programed into the SPD
JLV2k5 Active Member Jan 14, 2008 #7 Enhanced performance profiles? And what is SPD, I have no clue...
StrangleHold Moderator Staff member Jan 14, 2008 #8 Right, nothing you cant do manually but if it has SLI on it they guarantee the settings to be stable. Last edited: Jan 14, 2008
