CrimsonVerbs
I am not a cheap-o I just have been using a pc for so long and I am a flash designer so for me, it works. For image processing, etc. I have no idea...
I am wondering tho.... What you think will be ample enough for my wife, she is a photographer... Money is no object and she shoots ALOT she has 2 cameras both that have 50 megabyte files per image sometimes....
we where looking at the Mac Pro.... I am thinking if I get one off ebay its around 2000 less than in the store... w/warranty and there are a couple of deals on there... I would like not to spend more than 3,000.00 for the tower itself.... and 500 for the 23inch monitor which I've already found....
what do you think of these deals??
http://cgi.ebay.com/ws/eBayISAPI.dll....cWAT.m240.lVI
I don't know the difference between quad core and dual core, and really... am I going to see much of a difference?? If any.... I would like to spend less, but if u really think the quad core is imperative I will go with a newer model...
As you can see with the ones I've picked out already, they all have different amounts of hard drive space, ram space, and ghz (also quad and dual)..
I know i'd like to have at LEAST a Terabyte of storage, if not more, the ones listed above seem to have at least that...
As far as memory goes, how much is too much???
Thanks for all your help, again I am a little at a loss for all this stuff because I am a pc user...
Also, do you think it would be better NOT to buy from EBAY and look into buying direct?? Or a refurb?/ Also, can you add more Memory, Hard Drives etc. w/o going through the mac outlet for all your upgrades??
David
____________________________________________
***edit those links up top^^^ are actually all quad-cores
here is another link to a dual core I was looking at earlier but it sold already:
David
