question about a power supply...
Drinibeans1
quick question...
is it bad to run a power supply outside of the computer case?
i have a slim computer and dont wanna try to find a more expensive one that will fit...so can it be done?
any problems associated with it?
No problems, more air flow in the case, and most likely a cooler system and power supply overall. Although it looks rather crude...
I think it's a great idea as far as cooling goes. If you don't mind how it looks than great. Anything to keep the box cooler is great.
there is nothing wrong with it. i have no head issues. my cpu runs at 21C and its a quad so i dont see why heat would be your issue.
