HP system restore from HD Partition
uposb4
How do i go in and do a system restore on an HP? No restore disc came with system and told eveything is on the partitioned hard drive. Thanks.
Click on "Help and Support" icon in your Windows
In the Search Window in the upper left hand side of the screen type "System Restore Wizard"
In the two options you get from this search select on "Run the System Restore Wizard"
You should be able to figure it out from this point.
or you make your own cd's go into the start and look ofr hp and there is some wizerd to make dvd's
That's what I would do. You're suppose to be able to boot into these recovery partitions, but it doesn't always work. There should be an application that allows you to create recovery disks.
HP restore
Thanks, When i go in and create the restore cd's, Will it burn only whats in the partition such as OS and originally installed programs from factory or will it burn all the programs and crap that i added later thats accumilated such as games and ISP software? Thanks again.
