It will not overclock it, it doesn't set the speed any higher then stock, it just lowers it.ok but will it automaticly overclock it when needed?
why do i have to drop my ram to 667?You can overclock through your Bios. They make Windows overclocking programs but its better to overclock using the bios. With yours you would disable Cool n Quite- Drop your Memory from 800 to 677, unless you want to overclock your memory too- drop you Hypertransport from X5 to X4- manually set your PCIe bus from auto to 100MHZ- Then start raising your Bus from 200MHZ up about 5 MHZ at a time till it get unstable then back off a few MHZ. If you want to go higher you will have to bump up your CPU voltage by (small) amounts. And keep a eye on your CPU temps. And with a Gigabyte to get to the overclocking features, when the bios loads you have to press Ctrl and F1 at the same time to open more bios features.
All of the current AMD and Intel processors have locked multipliers, except for the AMD FX and Black Edition CPU's, and Intel's Extreme series.this CPU (and most other AMD) has a locked multiplier right? you can only OC by changing the core speed right?
You don't need to drop the RAM down to 667, although when you overclock your processor it will also overclock your RAM. So by lowering the RAM speed you will rule that factor out when it comes to testing stability.why do i have to drop my ram to 667?
why do i have to drop my Hypertransport to X4?
how much volts is a little?
whats the highest ideling temp i should have?
sorry for so many questions
