Motherboard for Intense gaming
Savassan
Hey there everyone, Im rebuilding my computer thats about 4 years old. So almost everything is getting replaced. I dont have tones of money to do it with or anything tho. I mostly spend my time playing games like Bioshock, Crysis, things along those lines. I'm looking for a Mobo (pci/pci-e) (duh) that will support playing games like this on relativly high settings. Any ideas out there for what exactly I am needing? I'm not terribly computer smart where it comes to the hardware aspect of it but I know enough. Thanks for any help i get guys
-savassan
Can you give us a budget? (not necessarily a pin point number, but at least an general idea)
That way we could help you a lot more.
Oh yeah sorry, thought I had. For my graphics card im wanting to spend ~300 max. The Mobo and CPU i dont have a clue. But total im not wanting to spend much over 700. Thanks.
Alright, well list what you have right now. (Or are you wanting to make a completely new build?)
well the problem is, the computer that im remaking cant even boot up and is at my House 2 hours away (currently at college) so i cant provide the specs.... So yeah its mainly going to be a new computer. The Hard drive is a seagate, and the powersupply is 650W.
Mainly wanting to just replace the RAM/CPU/Grapics/vidcard/MOBO
Alright check these.
For your MOBO
option #1 cheap yet good
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131142
option #2 a tad more expensive but worth it
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188012
RAM that I suggest if you choose one of those nForce boards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
Nice speed, stable, and pretty cheap.
As for a CPU what do you think about this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115018
Core 2 Quad, very good, I'm buying one with my new pc.
as for Video cards, I highly suggest an 8k series GeForce, best out there IMO
A cheap way to go is an 8500 GT with 512mb GDDR2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150245
or if you are willing to pay more for your grphx card, try the 512mb 8800 w/ GDDR3 512 mb RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121224
Well, those are my suggestions, take a look and see if anything "Tickles your fancy" so to say. With those parts, they hold about under $700
*edit* If you're looking for real extreme motherboard, try this:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131235R It supports DDR3 RAM
I would go with a 8800GT 512mb for your GPU.
The quad core CPU that Astoroth88 posted is also what I would recommend or if you have more cash to spare on CPU get the 3.0ghz Core 2 Duo (Not that much more. it's what I have). The core 2 duo has higher clock and also has a fair amount of room to be over clocked. The quad is better with multi-tasking however I keep hearing that the quads aren't that much of a difference. In the future computers will make more use of the quad but for now the core 2 duo is still good. Core 2 Duo 3.0ghz is probably better for gaming then the cheaper quad CPUs (Q6600 ).
I would go with the EVGA 680i motherboard (also what I have).
That is around probably around $750 and then you need ram. 2x1GB can usually be had at around $60-$80. So around $800-$850 if you look for the deals ($835 on Newegg).
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028
Motherboard and GPU: Posted below by Astoroth88
well when i built....rebuilt my comp...i spend only 400 but i thot it was ok.but i don't play crazy games or anything so...its ok i guess. i never had an amd processor so i decided to get this as my build:
AMD dual core x2 6000+ @ 3.0ghz, no overclock -160
Asus m2a-vm mobo....should've went for the asus m3a-vm...only 15 bucks more.-75
Kingston HyperX pc6400 2gb kit...2x1gb..... .-70
just so you know...try slickdeals.net or .com (iforget) and u could find ram for much cheaper.
they had ballistix (i think by crucial) 2gb kit for only $30 but it was too late for me. good luck w/ ur build.
really no reason to buy an amd right now as the c2d's outperform the amd's and the price is significantly better. the g.skill ram i bought, 2gb, was $45 shipped, and it's great ram.
for the graphics i would go for the HD3850 (512MB) fairly cheap good preformence it will get
play crysis at med settings @1024x768
<b>let me show you, how you can use my
simple & proven techniques to work for
yourself and make $5,000-$10,000
a month like clockwork.
All you need is a little sales experience, and you will make it happen.
We created high-quality products for the general public; all you need to do is contact us today.
In these difficult financial times
the only selling products are small priced products.
This is exactly what we made for you.
We guarantee you <u>$200.00</u> a week base, so you can feel good about your new lifestyle and you can join the thousands of people just like you that started their own business & are making $5,000-$10,000 today.
Please send you resume to [email protected] or call
ms. Silvia gonzalez today at 954-391-1130
for more information please visit our website: http://www.viaxtreme.com
or e-mail us with any questions:
[email protected]
</b>
spammer
