My goal is an all purpose machine. I do not want to go over $1600. I would really love to have a monitor that can display component/s-video/composite inputs as well as have a DVI connection. It dosent need all three inputs but it must have DVI and one of the others at least. Don't factor MIR into the budget, but make the total after shipping/tax. ships to 95616. Everything bought from the same site(newegg should work for that anyways). I will do semi-heavy gaming on it so decent gpu is a must. I will be encoding video on a semi frequent basis (VOB -> Avi -> mp4). 320gb or larger hdd, 2gb of RAM. The thing that I am not sure on is Blu Ray, I kinda want it but I wont be heart broken without it and I figured with the larger budget it is worth it for me. This will all be put in a CM690 case. USB backpannel ports are a HUDE plus b/c i have quite a few peripherals (2 external hdd's, mouse, keyboard, Camera, webcam, ipod, printer), but i can allways buy usb hubs to make up for that.
Oh, also would like p35 chipset please, might consider an x38/48 board if its in budget, i want semi future proofing with the chipset so those three chipsets only please
SATA cables:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812123158 X3
DVD Burner:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
Multi-use Monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824255003
GFX:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
Blu ray Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106227
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211174
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128064
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
Case Fan(s);
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185006 X4
CPU Heatsink/fan:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Total after shipping & tax ..... $1588.68
Please stay under budget and any comments are welcome
SATA cables:
DVD Burner:
HDD:
Multi-use Monitor:
GFX:
Blu ray Drive:
PSU:
RAM:
Mobo:
CPU:
Case Fan(s);
CPU Heatsink/fan:
