I've been using this SP3 pack since it came out without issue until the other day..
I had slipstreamed it onto my install discs using nlite.
When trying to do an install on a system with the VT8237 chip the sata drivers (the f6 ones) failed to copy to the drive after formatting... They worked fine for the windows install to see the disc and format it..
I tried different drivers from 4.10 right up to the latest ones 5.60a and none of them worked.. ( I even tried slipstreaming a couple)
The install went just fine when I went back to my SP2 disc.
BTW.. I tried it on 2 systems for giggles, a socket a ECS board and a 754 DFI with the same results, so it likely wasn't the boards..
On a side note Vista SP1 has solved all my network file transfer and My Pictures screen saver problems. I installed it over a fresh install of Home Premium and it certainly is an improvement.
