My first Rig, opinions?
Akareza
Intel Core 2 Quad Q6600 Quad Core Processor ($269.99)
http://www.ncix.com/products/index.php?sku=22211&vpn=BX80562Q6600&manufacture=Intel&promoid=1019
ASUS P5K-E/WIFI-AP ATX LGA775 P35 DDR2 1333FSB 2PCI-E16 3PCI 2PCI-E1 SATA2 ($154)
http://www.ncix.com/products/index.php?sku=25851&vpn=P5K-E/WIFI-AP&manufacture=ASUS&promoid=1019
EVGA E-GEFORCE 8800GTS 112SP 576MHZ 640MB DDR3 (Already have this)
http://www.ncix.com/products/index.php?sku=27091&vpn=640-P2-N829-A3&manufacture=eVGA
Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24PIN ATX Modular Power Supply ($134.99)
http://www.ncix.com/products/index.php?sku=19831&vpn=CMPSU-620HX&manufacture=CORSAIR&promoid=1019
Western Digital Caviar 750GB SATA2 7200RPM 16MB 8.9MS Hard Drive ($159)
http://www.ncix.com/products/index....AAKS&manufacture=Western Digital&promoid=1019
Mushkin HP PC2-6400 HP2-6400 2GB 2X1GB DDR2-800 CL4-5-4-11 240PIN DIMM Dual Channel x 2 ($56.29)
http://www.ncix.com/products/index.php?sku=21095&vpn=996533&manufacture=MUSHKIN&promoid=1019
Noctua NF-S12-1200 120MM Ultra Quiet Cooling Fan 1200RPM 81M3/H 17DBA ($18.99)
http://www.ncix.com/products/index.php?sku=21012&vpn=NF-S12-1200&manufacture=Noctua
Samsung 226BW 22IN Widescreen LCD Monitor Glossy Black Finish 1680X1050 ($303.72)
http://www.ncix.com/products/index.php?sku=22783&vpn=LS22MEHSFV/XAA&manufacture=Samsung&promoid=1019
Antec Sonata III Black ATX 16IN Mid Tower Quiet Case ($109.01)
http://www.ncix.com/products/index.php?sku=24294&vpn=SONATA III 500&manufacture=ANTEC&promoid=1019
Pioneer DVR-212D Black DVD-RW 18X6X18 DVD+RW 18X8X18 DL 10X SATA 2MB OEM DVD ($28)
http://www.ncix.com/products/index.php?sku=23283&vpn=DVR-212DBK&manufacture=Pioneer&promoid=1019
ASUS 16X DVD-ROM Drive SATA Retail Box W/ Black & Beige ($28.38)
http://www.ncix.com/products/index.php?sku=26375&vpn=DVD-E616A3T&manufacture=ASUS
Zalman CNPS9700NT Copper CPU Heatsink 110MM Fan LGA775 AM2 S939 1250-2800RPM
http://www.ncix.com/products/index.php?sku=21680&vpn=CNPS9700-NT&manufacture=ZALMAN TECH
Total: ~1500 $ CAD after tax
Will the parts work together well? esp the mobo/ram/cpu. have windows media 2005.
Anything else missing from there (not sure) or any recommendations?
Would really appreciate the feedback as i want to make this to last me a for a good while & work properly
thanks
Don't get the 640mb GTS. Get the NEW G92 512MB GTS
Also what OS are you going to run? i would get no less that 2GB or ram, if you get or have a 64bit OS 4gb is always great.
Also, why not get both cd drives in SATA?
I already have the card by set up, is there a big difference between the two?
my os is 32 bit... good point about the drives, i just picked them up randomly base of price/feedback.
anything else i am missing in the list? i think cpu heatsink..
Yes, it will all work together. Another alternative to the motherboard would be the Gigabyte P35-DS3R. Both the P5K-e and DS3R are great boards.
I would suggest an aftermarket heatsink for the Q6600 such as a Zalman 9500 or 9700.
Also maybe get two of the same drives so the match each other? just personal opinion :P.
Also i would get a case without a power supply since you are going to need the corsair unit you have listed anyway. If you get a case for $100 without a power supply included, you will get a much higher quality case.
The case was the highest rated one from that site (since i mainly order from there) for what i wanted, ie very quite and not any significant (or even minor) negatives.
i will check the drives :P
ncix is a canadian site isn't it? if so, you may want to try directcanada.com, they're cheaper even though they're a subsidiary of ncix.
i've got the stock cpu heatsink/fan for my amd 5600+ dual core and i'm running at 31 degrees cpu temp, and 29 degrees system temp. the only other cooling i have is an 12cm fan for exhaust and the smaller one for intake (88mm?), and i guess i can mention the 12cm fan in the psu, but the case has a completely meshed front panel so air flow is exceptional. so i'd say it all depends on your system, and what you'll be doing with it. if you'll be doing graphic intensive gaming, or video editing/encoding on a mass scale, i don't think you'll be needing the aftermarket fan/heatsink for the cpu.
Ahh crap something i might have completely forgot about.. i want to be able to watch TV on this comp (with cable) i am pretty sure my video card has a TV outlet but is that all thats required? (have winders media 2005 os) also will i need a sound card with this build?
Just to update i have received all my pieces except the memory ( back ordered ><) and thanks ThatGuy16 i got that heat sink for the cpu too.
ahh after researching abit, seems like i need a TV tunner to watch TV on it.. do they have specific specs? i have one on my dell computer that i could use if compatibility is not an issue (P4 computer 2 year old, PCI E)
You don't need any specs to play videos/TV. The older, the slower and choppier though. I'd recommend 2.4GHz or above with at least a Radeon 8500 or GeForce FX :)
