Synesthesia
Setup: 2x 2gig OCZ Reaper 800mhz, above board, 2.6 GHZ core 2 duo, Zero Therm Nirvana, Thermaltake Tsunami case, MSI 8800 GT OC, Ultra X-connect XVS 500 Watt PSU, Rosewill PCI usb.
When I press the ON button, all of the fans start up, but it never makes any noises, nothing appears on the screen or even causes the screen to react, and the D-Bracket diagnostic tool doesn't display any diagnostic lights-but power is in fact going to it since I tested its built in usb ports. Me and a friend troubleshot it and weren't able to fix it. I tried one ram, then another alone, tried a friends 7800 GT to see if it was my gpu, it wasn't, replugged just about everything back in and triple checked everything...WHAT DO I DO NOW!? Should I just RMA it (Whatever that stands for) back to newegg? I need this thing to work, I spent 1/2 my bank on it.
....I installed the cpu perfectly, followed how to do it by the book, even had someone help me do it, who had done it 3X before! I checked all of the grounding, and the mobo seems perfectly grounded; the case came with this blunt screw like thing to put it 4mm above the mobo tray, so I put the rest in, which all rest on the bottom side of the mobo; the screws went into them and now hold it down.
