rate my rig
atreyurock
i just built my comp, what do you think, Prices is in canadian
myFrom ncix.ca
-LG G-H20NS10 Black DVD+RW 20X8X16 DVD-RW 20X6X16 INT SATA OEM DVD Writer $29.99
http://www.ncix.com/products/index.php?sku=27454&promoid=1001
-Western Digital Caviar SE16 250GB SATA2 7200RPM 16MB 8.9MS Hard Drive
$69.99
http://www.ncix.com/products/index.php?sku=16141&promoid=1006
-OCZ Platinum XTC REV.2 PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-15 240PIN DIMM Dual Channel Memory
$64.99 After Mail In Rebate: $29.99
http://www.ncix.com/products/index.php?sku=19337&promoid=1006
-Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
$93.99
http://www.ncix.com/products/index.php?sku=25369&promoid=1006
-Visiontek Radeon HD 3850 256MB GDDR3 PCI-E Dual DVI-I HDCP HDMI HDTV Out Video Card
$174.99
http://www.ncix.com/products/index.php?sku=27075&promoid=1006
-Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB
$239.99
http://www.ncix.com/products/index.php?sku=27784&vpn=BX80570E8400&manufacture=Intel
From tigerdirect.ca
-NZXT ALP-001 Alpha ATX Mid-Tower Case - Clear Side, Front USB, Audio, eSATA Ports
$73.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3438627&sku=A406-1084
-Ultra / X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready / Titanium / Power Supply $49.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1273340&CatId=1483
altogether with shipping it comes out to $941
im was thinking about it, but i only play RTS games and the odd shoter's like fear,COD4, etc so i think this should do fine for now, i hope
Don't worry about him, he's obviously on crack if he thinks a E8400 is slow. 4GB would be nice for Vista, but 2GB will do just fine.
obviously i wasnt referring to the processor. i was referring that your running vista on 2 gb instead of 3 or 4 gb
you need to stop smoking crack, 2gb is perfectly acceptable for vista. vista only uses about 10% more RAM then xp
I’m going to run XP to start then Vista once it's a smother running program (when they fix some bugs) then I’ll run 4 gigs of ram
The video card you chose is a newer version of mine, so it should run fear much smoother than mine. (Mine is just slightly laggy at times)
Unless it's Ultimate. I'm doing it on Ultimate, and 1/2 the time virtual memory comes in during gaming :mad:
I don't think there's a difference between Home Premium and Ultimate that would suck more memory, most of it's features are just better networking capability. I could be wrong though.
I've been corrected, better security features and networking. Still, I don't see it taking up much more RAM.
It does, trust me on that part. Personal experience tells so. Once on plain idle with absolutely nothing going on, the Vista memory meter told me 33% was used. Out of 2GB too :eek:
home premium has the same utilization of RAM at idle
everything vista ultimate offers over home premium are features you must still activate/turn on, they arnt background
