Which thermal compound to get...
Michael
I'm in need of new thermal compound for my video card and the hsf for both computers.. but I'm not sure which to get.
I found this; Arctic Silver Ceramique Thermal Compound - OEM.. but know nothing about it.
I need to re-paste my 7600GT (the stuff that was on it came off like bread crumbs with a very light touch.. no wonder it idles above 60c) and both PCs (x2 3800+ and a 3500+, both with stock hsf .. which work fine, but I want to re-paste them anyways)
So, is the stuff above fine? .. or should I be looking for something else? :D
-mak
I won't use an electrically conductive paste for my video card, since the chip has exposed diodes.. so AS5 is out of the loop.
From what I've been reading, since I posted this, the paste I linked to is of high quality.. I just need to know if anybody here has used it for their cpu, if so, did it work out for you?
-mak
I used it once, because I didn't have any thermal paste handy and it was just some crate I had kicking around. It actually works quite well. Don't knock it until you've tried it (which you obviously haven't).
You're correct, I haven't.. but then, how many have?
I'm not knocking it, regardless.. I thought you made a joke, and replied accordingly ;)
Toothpaste works... trust me. When you're in a jam, you'll learn to appreciate it. lol
i can't tell if this is sarcasm or you're for reals. if it really does work, i don't get how it conducts heat if it doesn't really have anything metallic. if anything, it will insulate right? how does the chemistry work?
lots of people say mx-2 is really good, i enver tried it, i'm using as5, and it works great for me. i didnt really know what i was buyin, but that was then this is now, it works for me, i think u should go w/ as5, only because i used it.
