Will this PC cope?
kingnothing48
Will these specs be ok for games like COD4, Crysis, Cs:Source...etc.
Processor: AMD Athlon™64 X2 5200+ Dual-Core CPU HTT
MoBo: Asus M2A-VM AMD 690G Chipset
Memory: 2048MB [1024MB X2] DDR2-800 PC6400
GfX Card: NVIDIA GeForce 8400GS 512MB w/DVI + TV Out
HD: 160 GB HARD DRIVE [Serial-ATA-II, 3Gb, 7200 RPM, 8M Cache
Let me know what you guys think...
It will not play Crysis or CoD4 at anywhere near decent framerates, although it will play CSS around low/medium settings fairly well.
it's the video card thats holding you back. Theres also NO reason to get a 512MB version of the 8400GS.
Well it depends on your budget, but if you don't mind spending around $160 then the ATI 3850 would be a great choice, or the 8800GT if you can afford over $240. However if you are on a very tight budget, I would go with at least an 8600GT(S).
