com. under 700 dollars? tell me what i can get
mortonman1
i dont know what to get, maybe this. i might play crysis, im not looking for extremely high preformance. remember under 700...
this is what i have in mind...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998123
DVD/CD burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144102
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136195
80GB HD, its small but im going to buy more later on
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127305
2600xt
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
2 12v rails
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148069
RAM DDR2 1066
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128077
Motherboard, hope its good, it was suggested to me by another member
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115031
2.2ghz CPU(core 2 duo)
and then im buying this IDE to serial-ATA adapter so i can hook up a 40GB IDE drive. also im getting an extra 120mm case fan.
dont be harsh if it sucks, thanks guys
E6750
P35-DS3L
2GB XMS2 CL4
WDC SE16 250GB SATAII
Centurion 5
Hec Orion 585W
Writemaster DVD Burner
HD3870 512MB
I like the case choice! I'm going to build another comp sometime in the near future and use that case.
