JL2VK I cannot find the specs, it's a very cheap sempron computer.
it's a year old, sorry about the typo, so it's 1 year old acer computer. I am planning to replace the 250W psu with this 500W psu in order for me to use my new ATI x1950Pro which requires 30Amps on the 12V rail in order to run. Ceewee, if that's the case, would it still work?
Here are the PSU specs i am planning to get:
Brand COOLER MASTER
Model RP-500-PCAR
Series eXtreme
Spec
Type ATX from factor 12V V2.01
Maximum Power 500W
Fans Sleeve bearing 120mm fan
PFC No
Main Connector 20+4Pin
+12V Rails 2
PCI-E Connectors 1 x 6Pin
ATI CrossFire Support No
NVIDIA SLI Support No
Modular Cabling Support No
Power Good Signal 100-500ms
Hold-up Time >17ms
Efficiency >70% typically
Over Voltage Protection Yes
Input Voltage 110 - 115V/220 - 230V
Input Frequency Range 50/60 Hz
Input Current 8A/ 6.3A
Output +3.3V@20A,+5V@20A,+12V1@16A,+12V2@16A,
[email protected],
[email protected]
MTBF >100,000 Hours
Approvals Nemko, TUV, cUL, CE, BSMI, FCC, CCC
Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V(P4)
6 x peripheral
3 x SATA
2 x Floppy
1 x PCI-E
Features Green power design to meet energy star and blue angel requirements
OVP / OPP / Short Circuit Protection
