I've been having the problem recently where Windows XP will be running fine for five minutes or so, then for a small duration (around 20 seconds) it will grind to almost a halt (mostly noticeable in games or videos, where the frame rate drops to only about 3fps).
When running XP I thought that the problem may be due to a background process, but I recently got Vista and it's doing exactly the same thing!
Using the resource monitor, I see that the task audiodg.exe is jumping up in CPU usage during these slowdowns. It seems like having the soundcard set to 2 speakers rather than 5.1 makes the slowdowns less frequent and shorter in duration.
Here's the spec:
AMD Athlon 64 X2 3800+ Dual Core (2ghz)
1GB RAM
nVidia Geforce 7600GT (512MB)
Realtek HD Audio (Integrated sound card)
Only other peripherals are 1x120GB and 2x40GB hard drives, and a wirleless PCI network card (Buffalo).
Please, does anybody know what's causing this? It's making the computer almost unusable.
Here's the spec:
1GB RAM
