diduknowthat
formerly liuliuboy
So my new X-fi Xtrememusic came today and I'm having trouble adjusting it so that it plays through all speakers when playing stereo mp3 files. Even the audio configurator isn't working for the rear channels. Help!
[-0MEGA-];885339 said:It can be confusing on the X-Fi because they aren't color coded, so you need to be sure you didn't mix the cables up on a 5.1/7.1 setup Daisy.
The X-Fi (at least the XtremeMusic and higher end versions), are not color coded.Soundcard have 4 hole. Red, Green, Black, Yellow. My creative 5.1 have Red, Green, Black. So I plug it according to the color.
The L/R front have sound when I change the setting in the Creative's control panel as 2.0
But no matter I change it to 5.1/ 7.1 setting at the control. No sound from L/R front. Can't figure it out.
[-0MEGA-];885436 said:The X-Fi (at least the XtremeMusic and higher end versions), are not color coded.
Which version did you have? I bought the XtremeMusic the day of the release, and I recently bought an X-Fi Fatal1ty as well, both look exactly the same on the back with no color coding. If you have something like the XtremeAudio, then those are color coded.Mine did. May be a older version??
Edit: I don't mean the color on circle plug, The color is actually on the golden plate...
The X-Fi comes with a sticker which can be applied to the back so it's easier to tell where each speaker cable connects, so HP may have applied it.I remember it was X-fi Xtrememusic OEM when I bought it.
I opened the case, it say creative labs SB0670. But when I type it in yahoo, it say OEM for HP....
Checking in Everest. It say Creative CA20K1 X-Fi Xtreme Fidelity Audio Processor.
I am confused...
