What kind of connection are you using?
The computer has picked up something, or something has disconnected.bingbonG??
That would be my first suggestion as well, especially if it's drawing all it's power from the bus.It'll be because you're running it off a hub. Some things just don't like it. Give it a dedicated port
I have tried to connect straight to the motherboard firewire port. It semms to work ok, but since yesterday, it has started not showing up again, though you hear the bingbong. If it gets disconnected, should not hear the bingbong twice?
