Windows Vista 32-bit Question
2048Megabytes
What is the normal amount of memory Windows Vista 32-bit runs at when just idling? Someone I know says when his Vista 32-bit is running it is taking around 900 megabytes of memory. Is this normal?
He wants me to take a look at his computer. I'll probably run some anti spyware programs. I think malware may be at work in his system.
He also has a Pentium D processor. Since you have a dual core, could the single core processor be an issue with more memory being used?
No, vista has a shitload of eye candy and pointless processes that run in the background, its normal to have quite a bit of memory taken up during idle. i had ultimate like oscar was saying and it idled at around 20-30%usage. Here is my advice, upgrade to Win XP and your problems of memory usage are solved.
nope, vista uses less memory on basic level then xp on basic... surprisingly
