How to import Xvid videos to windows maker?
UpskirtHayley
How to import Xvid videos to windows maker? I tried it but it kept saying I cant cause I did not check box something like that.
2:
when im done with it and click save.... what format is the most high quality? I tried (high quality large) and (high quality ntsc) but all reduce the quality from orginal file.
3:
is there a way to save my vidoe when done in xvid format in windows maker?
i have never imported xvid or even divx in WMM, i used only wmv or avi, but am not to sure if it works
2:
i myself use the one you mention but thats just movie maker, your output won't ever be crystal clear, have you tried high quality video NTSC ?
3:
no, you simply can't
1:
Use virtualdub which I recommend, or another video converting software to temporarily convert to uncompressed, then import.
2:
High quality large is best if I'm not mistaken. High quality large and high quality ntsc are the same quality, but ntsc is a different dimension (720x480 instead of the normal 640x480, ntsc is a little wider and disproportioned). It reduces quality from the original file because of the codec and compression method it uses. Use nero or another video editor to export in higher quality avi in where you can choose the level of compression.
3:
No, windows movie maker uses wmv format+codec only. Use 'nero vision' for that kind of editing & exporting.
