He was saying nm, which is the correct term used when talking about the process size of CPU's.That would be "MM" not "NM" for millimeter only referred to as "nanometers" another unit of measurement for the size. 1 millimeter is equal to 1,000,000.0020115 nanometers. So what does 90nm equal? 0.0000899 millimeters. It's simply a much smaller unit of measurement.
Since when did metric conversion involve more than changing exponents? Nano = 10^-9, milli = 10^-3; so 1 nanometer = 10^-9 meters and 10^-6 millimetersPC eye said:That would be "MM" not "NM" for millimeter only referred to as "nanometers" another unit of measurement for the size. 1 millimeter is equal to 1,000,000.0020115 nanometers. So what does 90nm equal? 0.0000899 millimeters. It's simply a much smaller unit of measurement.
[-0MEGA-];888960 said:He was saying nm, which is the correct term used when talking about the process size of CPU's.
The website is wrong - not everything you see on the internet is right (though in this case they're very close - they just display too many digits). It may be floating point error or something, but that's the beauty of the metric system - you don't need conversions, it's all factors of 10. That website also calculates that 1 meter = 1,000.000002 mmPC eye said:Try an online conversion and see for yourself! http://www.ilpi.com/msds/ref/distanceunits.html
conversion website said:The prefix "nano" means 1 x 10-9, so one nanometer = 0.000000001 meters. Alternatively, 1 meter contains 1,000,000,000 nanometers. Visible light contains wavelengths from roughly 300 to 800 nm. To convert this wavelength to energy, see the energy unit conversion page.
I don't care what some online calculators say; it's easy to write programs that provide wrong answers due to truncation error or floating point error. I have programs that say otherwise and the definition is quite clear - nano is precisely 10^-9. Even NIST (National Institute of Standards and Technology) says so.
I can agree with thatRegardless it still points out that "nm" represents "nanometers" being a unit of measurement as the answer for the question asked.
Why did you quote me?Transistor size, 45 nanometers is the size of the transistor. Because they are now smaller, the CPUs transistors operator more quickly and CPUs can contain more transistors.
Check it out here
http://news.zdnet.com/2422-13569_22-159214.html
What you are missing there with one site is why that shows 0.0000899 while the other shows 0.00009. For precise figures you often see the longer figure displayed while the other simply rounds things to the closest whole number.
Who is to say that 90nm isn't actually 90.032nm or 89.975nm and simply rounded off for marketing like seen with hard drives. Of course then you could even start a math thread in the off topic section to go into that further.
I have to weigh in with Yeti. A nanometer (nm) is, by definition, exactly 1 x 10^-9 meters (m) or 1 x 10^-6 millimeters.
The metric system is based around factors of 10^3 designated by prefixes.
Any variance from the above in a conversion program is due to error in the program.
You're either trolling or not familiar with metric...
Do you assume a 1gb dimm is actually 1,000mb or the actual 1,024mb and even that a 500gb hard drive is actually 500gb when seeing 465gb available after partitioning? You sound like the one trolling since the original question of just what the initials "nm" represented has already been answered.
