mortonman1
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156087
motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188021
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115031
Hard Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165007
CD/DVD Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135143
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Accessories:
Thermal controller/fan controller:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811995006
4 pin to 8 pin CPU power adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812887002
And thats it...
i will be doing minor overclocking later on after the warranty of the CPU expires to ensure that everything works properly. i might do some gaming to so i got the onboard video that has the nVIDEA 7150. they arent going to be games like crysis. i will mostly be listening to music, browsing the web, word processing and more/etc...
At my home i have an IDE Hard Drive that has lots of music and photos that i want on my computer so i will be plugging that into the computer.
Also is that power supply to weak or anything in case i were to get the 8600GT later on? people say it only needs a 350W PSU. thought im worried that it might need dual 12V rails... will it?
The thermal controller is so that i can monitor CPU temps and partially for looks. i know that if im not gaming i shouldnt need it, though i want to. maybe to 2.4Ghz or 2.6Ghz.
I appreciate all the help you guys are giving me, thanks. please look carefully to make sure they are compatible.
motherboard:
CPU:
Hard Drive:
Power Supply:
CD/DVD Drive:
RAM:
Accessories:
And thats it...
