Kornowski
I'm getting it very soon, and was wondering what the best arrangment for the fans would be?
I was thinking, having both the front 120mm fans in the top 6 bays and my DVD Drive at the bottom... and one 120mm on the side...
Does that sound Ok?
Also, what would be the best setting to have the fans on? Low, Medium or High?
Much difference?
I know that you can also put another 120mm fan behind one of the front 120mm fans, would that be a good idea?
and, lastyl
Is it Ok to remove AS5 with alcohol wipes, for the HSF and CPU?
Thanks
Does that sound Ok?
Much difference?
and, lastyl
Thanks
