build
pc-tech
banned
im building myself a new, good computer, the only thing im keeping is the case i need a cheap, but good parts list please
thanks
will be for internet schoolwork/buisness, etc
already have the os, xp sp2
must be fast:D
Thats very vague. How much money are you looking to spend? Is the computer going to be used for gaming (new games)?
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128080
RAM x2 u will be able to drop the timmings on these to 4-4-4-12 fairly easy if u want to
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220228
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156062
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136012
an then but a nother SATA drive if that is not enough room
Vid card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131038
this comes to a total of $850.93 an it will be very quick
EDIT i know only 3G of that will work it was just so u can have duel chanel with same chips
CPU
MOBO
case
HDD
Vid card
He is not gaming.
IMO, WD Rapor is not necessary. I personally will suggest to go for a normal 250GB HDD.
GPU: I would suggest go for HD3450 than X1550, as HD3450 could support HDCP.
Case+PSU: The single +12V@22A seems a bit low...
May be SILVERSTONE ST40EF ATX12V Ver.2.2 400W/ CORSAIR CMPSU-450VX
Build A Desktop From Scratch
Hi, i am planning on building a Dekstop PC from scratch but i need help choosing the components. I know what i need but in which order would you buy them so that you know all of it will fit.
EG, the Motherboard, Case, Central Proccessing Unit and the power supply. In which order would you buy these.
Any Ideas?
He is not gaming.
It isn't necessary. SATAII and 250GB/320GB as stated.
X1550 is an OK card, but look at the 7300LE. Now google 7300LE vs X1550. 7300LE wins. HD3450 is a great card, but requires some airflow.
22A is very low. My $30 PSU has 39A or so total....
