MosIncredible
OK, after doing a ton of research on this site, I've decided everything I will buy other than the PSU and will be purchasing within the next week or so. I'm looking for recommendations on which PSU to get with this system. I'd consider myself experienced inside of PCs but I've never actually built one from scratch. Here's what I'm getting...
CPU: E8400
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037 price keeps rising
HS: Zalman 9700
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
MB: Gigabyte P35 DS3L
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
GPU: XFX 8800GTS (G92) 512MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150261
RAM: 4GB Corsair XMS DDR2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
HDD: WD 500GB 16MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
DVD: Undecided but wont effect anything.
CASE: Thermaltake Armor 8000
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133154
OS: Undecided which will also affect the RAM purchase. I may have to go with XP because of drivers for my MIDI sound card. This PC will also be a studio.
Any suggestions on different cases, PSUs, WD vs. Seagate? I've had a WD for 6 years now with no problems so its hard for me to choose something else.
Is the GTS worth the extra $60? I'd hardly call myself a PC gamer (mainly because my current PC can't) but I'll start if I get a GPU that good. Even if I don't get deep into gaming, I like to future proof (hard to call anything future proofing nowadays I know) because I won't upgrade often at all. I'll probably have this exact same PC 4 years from now. Maybe a different OS.
Any help appreciated.
CPU: E8400
HS: Zalman 9700
