desktop wallpaper???
Vizy
Hey, i had this crazy looking wall paper....which my lil bro changed and i dont remmeber the site from which i got my old one...is there any way of getting my old paper back??? heres my screen shot from earlier:
i don't understand, is this the wallpaper you want ?
your wallpaper is somewhere on your pc.
if you go to "DESKTOP" tab in Display properties.
it will list all the wallpapers you recently used
from there you'll see the filename and you can search for it
And if it's not listed there(sometimes, it's not listed for me), then use Search and in the filename, type "*.jpg" without the quotes.
It will list many files. Switch to "Thumbnail" view and find the location of the file.
its not there because i got the image straight from online, i right clicked and set to desktop image.
what if i didn't save the image on my hardrive? i right clicked and set to desktop image online.
i
i think it saves it on your hard drive even if you just applied the wallpaper from online, it has to be somewhere, did you do the search like Adarsh mentioned ?
ooops firefox autimatically clears everything...and i run windows washer evryday bfore i shut off comp..
this was a good lesson for you to activate that service... why would you cancel it??? OMG it doesnt take hundreds of GB on your HDD or 100MB ram.
and windows washer doesnt do very much...
if you want a good clean and fast computer
install xp
then a antivirus/antispyware
after several months remove the unnecessary programs/do a disk cleanup
and a check disk
then install a registry cleaner(registry mechanic is a good one)
clean your registry, and remove that program from your computer
done.
do this every 3 month or so
you dont need those extra softwares. they dont do much!
install xp
and a check disk
done.
people do it everyday to keep there PC clean and not get tracking cookies and other nasties.
It's in the Temp files. Unfortunately for you I'm too lazy to tell you how to get there ( find on Google ) I can only promise it's a hidden folder in a hidden folder :D and Firefox and washer shouldn't be able to delete it.
good suggestion - although I think that the wallpapers are saved as a bitmap so OP you might want to try *.bmp also.
best of luck
yea thanks lol. i clicked new posts, and i saw my name, and i'm like "i don't remember this"
:D lol thanks tho
