Rip_Uk
I am looking to connect my xbox 360 to my monitor in the signature. I have my monitor connected to my PC using a DVI cable. I know that you can get a VGA cable to connect the xbox to a VGA monitor. Can i just use a converter to convert the VGA into DVI to go into the monitor.
Also, Is there anything that exists that I can plug both the DVI lead from my PC and the VGA/DVI lead from my xbox into which connects to the monitor which will allow me to quickly switch which lead I want to display from?
The audio is not a problem, I will connect this to my amplifier.
