JohnJSal
The mobo is pretty much the only decision I have left (aside from the monitor). Here are my options:
X38:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128080
P35:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128083
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128082
That last one catches my eye because it supports both DDR2 and DDR3 memory, so it seems good for future upgrades.
My big question is, how much of a difference does it make to have the FSB at 1600/1333MHz as opposed to 1333/1066MHz? Because that seems to be the main difference between the two chipsets. Everything else seems to be just a matter of how many ports are available, and if it supports dual GPUs, which isn't a priority for me since I plan to use nVidia anyway.
Thanks.
EDIT: Oh yeah, I plan to get the new Wolfdale CPU, so if some of these don't support it, my decision just got a little easier.
X38:
P35:
Thanks.
