andy_mitch92
i was thinking lately that i may want to try a raid setup on my pc. Is it actually worth it?
i never really understood raid, is it like having to hardrives acting as one? if so i would probably get a 10krmp for games and use the 500gig for data
what about for gaming (raid 0 i think) does this make 2 7200rmp drives act like a faster drive or what?
RAID makes two identical drives appear as one, and all data in both drives is identical; it's duplicated in both drives. In case that one of the HD's get screwed up, you still have one working drive; unless both drives crap out on you the exact same moment, you've lost nothing, as all the data is safely stored on the working drive. It might be worth it if you store all your mission critical stuff on your PC, and/or if your work/living largely depends on your computer or whatever is on it. However, for an everyday user, RAID is little if no use.
Performance wise you do get faster throughput when copying/loading/writing large files, which makes most games and programs load a bit faster. However loading times really won't be effected enough to notice a huge difference.I understand if one drive fails (which i've never had one do in my 6 years of computers) you loose all data. WHAT ABOUT PERFORMANCE? No one has answered that question and i mean in raid 0 for game performance.
In terms of access times and loading of small files, then yes. However in terms of max throughput, a RAID 0 array would still beat it.I've heard that 1 WD Raptor is still faster than two "regular" (7200RPM) drives in RAID 0. So maybe you should look into getting one of those.
