Help !! With Windows Movie Maker
vista18dc
Hi
I am trying to make a short collection of video clips which I filmed myself, I am currently using Windows Movie Maker (Vista) for the editing of it all, but when I import certain clips it always seems to crash and say its not responding and needs to restart, why is this always happening, and does anyone know of any alternative freeware, for the same job
Thanks
trakAxPC
create music and video mixes
trakAxPC enables you to create professional music and video mixes without any special skills or technical expertise. It provides a drag and drop interface to easily add files from your computer and to record from your microphone or web cam. The program supports beat matching technology, so your layered tracks will will rhythmically work together. You can create audio-only mixes or combine them with video and/or pictures. Other features include integrated CD ripping, audio and video effects, and more. trakAxPC is free to use, the company offers optional TrakPacks (audio loops and effects) that can be purchased. The program can render your mixes to WMA and WAV format.
http://www.snapfiles.com/get/trakaxpc.html
Maybe that will fit your need...
if you're willing to pay adobe premiere is very good.
i can never use windows movie maker. it either crashes or won't convert to dvd at the last step and gives odd reasons like "not enough space" eventhough i have plenty or "can't export to dvd b/c not enough space".... wrong again wmm!
Unlead Video Studio 11Plus is way cheaper and is like a final cut express:) I use Unlead Video Studio 11Plus;) And it only costed 80Euros rather than Adobe Premier Pro which costs like 700Euros here
If you want cheap cheap get Roxio VideoWave 7 or the latest one. Mine was like 8euros but it wont work on vista,:(
